Very loud howling from rear wheel 98 4runner limited
Old 09-12-2010, 07:11 PM
98Yotabeast's Avatar
I just bought a 98 4 runner limited with 130k miles on it. The rear passenger wheel is making a ton of noise with an occasional high pitched noise from under the center of the truck.
Is there a way for me to tell if this is a rear wheel bearing on the passenger rear wheel going bad or something coming from the rear diff? I plan to jack up the rear tomorrow and see if I can turn the wheels in neutral and try to pinpoint the noise.
Does the driveshaft carrior bearing make loud noise when they go out?
Any help is greatly appreciated.
Old 09-13-2010, 04:49 AM
Yukon's Avatar
Wiggle the wheel in the up down and around motion. It will be abel to side (a very small amount) OUT the axle tube, but shouldn't move up and down or left and right.
Old 09-13-2010, 08:45 AM
hross14's Avatar
Lift the truck pay close attention to the Differential also. They usually need servicing at about the ~100k mark.
Use a hose or mechanics stethescope to listen to the different areas.
Old 09-13-2010, 10:09 AM
txrunyota's Avatar
If there is oil on the inside of the wheel, its more then likely a wheel bearing. They can make noise when the wheel bearings go bad.
Old 09-13-2010, 12:31 PM
BigBallsMcFalls's Avatar
most likely the wheel bearing. that will go eventually if it has ever
been dipped under water a few times w/o proper follow up maintenance
oil doesn't always leak when these die. mine didn't leak, it just rumbled like hell
Old 09-13-2010, 04:59 PM
Thanks guys for the replys. I pulled the axel out today and the bearing sleeve came out in chunks with the center balls of the bearing exposed. Needless to say the wheel bearing broke apart, hence the loud howling i was getting all the time. it is getting pressed off tomorrow.
The brake shoes in the drum were coated with oil and brake dust. The shoes will be getting replaced and i will change the diff fluid as well.
toyota32
07-06-2015 05:42 PM
Vargntucson
07-04-2015 12:15 PM
CJ94yota
07-03-2015 10:14 PM
dlotoy4runner
7
07-03-2002 03:42 AM
Quick Reply: Very loud howling from rear wheel 98 4runner limited
