VERY dumb question
VERY dumb question
Hi everyone,
I am a new proud owner of a 4runner 1991 sr5 (22re)4x4.
The problem is i can't figure how to remove the spare tire(under the truck).
any help will be appreciate
good forum!!
good forum!!
A Vulcan mind meld should work for ya Spock
Actually if you lift up your rear seats there should be a long rod underneath it.
When I got my '91, I did not even know the rear sets lifted exposing the storage space under there for the jack and other stuff.
When you find the rod, there should also be a handle for it.
It might be in the very back in one of the cubby holes by the tailgate.
At the rear of your bumper is a hole.
You can see it in my pic here right above the red shackle.
Just insert the rod and then turn it counter clockwise I think.
The tire then should lower for you.
Welcome to YotaTech.
And no question is a dumb question
Pink Blanket Pic
Corey,
That pink blanket in the pic is just "so you!"
No question is a dumb question, unless you did not use the "dreaded flashing green button of death" first.
Now that was a nice touch!
Hi
It's seem to miss some hardware for raising down my spare tire.
Someone can show me a pics of what i need??
Do you know a another method??
seem to miss a rod.I have a" L" shaped rod(approx 12" lenght),a straight rod with a square shapped end with a bolt (approx 12" lenght) and a another 12" lenght rod with a flat curved end.
I do many research and did not find nothing.
any help will be very appreciate.
4runner 1991 SR5 4wd 4doors 22re
thanks
thanks
it seems like there was a longer rod hiding in the compartment you found everthing else in on my buddies runner. my dads p/u has a few rods that you connect together. i have nothing, a huge slot screwdiver does the trick but you have to get under the truck to reach it. pita!
