Valve cover gaskets replaced,now p0325 knock sensor code
OK,So after replacing my passenger side valve cover gasket on my 98 4runner limited 4x4,I now get a po325 code,Which is a no.1 bank circiut mallfunction knock sensor.I know this does not mean the knock sensor itself,But the wiring instead.I had to move around some wires and disconnect a couple plugs right behind the timing cover and I think this may be my problem.I'm going to try unplugging them,give them a cleaning and re-plug them.Has anyone had this problem?Thanks!
voiddweller
19
05-02-2016 10:10 PM
