Vacuum Gauge?
Vacuum Gauge?
Just a quick question about a vac gauge. If I hooked a vac gauge up to my N/A intake, would it be able to measure a noticable vacuum? Of course I'd run the gauge to the the throttle body, I was just wondering how much "vacuumness" there would be. Thanks.
or did i completely misread your question
Should connect the gauge after the butterfly valve or right before it? Aprox. how much Hg do you think it would measure?
I'm not sure what kind of vaccuum you'll see, I don't have a vacuum gauge on my truck, so I don't know what typical numbers are. But if I were to guess (and this is just a guess), I'd say you'd probably pull about 20 inHg of vacuum at idle and 0 inHg at WOT.
edit: it may be interesting to run a vacuum gauge before the butterfly. any vacuum there will show you how restrictive your intake is. but these numbers will be much smaller than a typical vacuum gauge reads, so you'd probably have to get a special vacuum gauge for that.
Thanks for the reply. Where would I hook the hose up to? One of the small pipes coming off the throttle body? Thanks.
i think this page has it. i'm not sure, i didn't fully read it:
http://www.4crawler.com/4x4/CheapTri...es/index.shtml
Thanks. I'll probably just mount it on a pedistal on the dash. Thanks for the reply.
