V8 engine swap 1st gen
i have a 81' with a 22r i want to put a V8 in it what engine is the best to put in where can i find the kit and what do i have to do to the drive train i want the engine to be basicly siock except for minor stuff
sounds like you're in over your head. there's no kit to do it, only parts that are helpful. may i suggest a 5.0HO out of an explorer or mustang, easier to fit in since the distributor is in the front
a much better swap would be to put in a big six like a gm 4.3, they're just as cheap as any v8 and better suited to a toyota
There aren't any "kits" to do this, just individual pieces. You'll need:
- Engine (only small-block Chevs and Fords have any support)
- TH350, C4, SM465, SM420, or NV4500 tranny
- transfer case adapter or custom crossmember for non-Toyota t-case
- motor mounts - Advance Adapters
- radiator - AA or Griffin
- Wiring harness and ECU for engine (and tranny) - if necessary
- Small stuff:
- Carb/EFI linkage
- belts
- hoses
- trans shifter
- alternator and/or power steering bracketry
- power steering hoses
- exhaust
- fuel lines
DjShiznit
07-05-2015 11:51 PM
thelifeadventure
07-02-2015 03:09 PM
