V6 3.4L air filter dimensions
I'm thinking of replacing the cyclone-type air filter on my Surf with that of a 3rd gen 4Runner. That way, I can use the amsoil air filter.
I would appreciate it if anyone can give me the dimensions of the box of the air filter so I can check if it will fit in the available space under my hood.
Does the box-type air filter have a performance advantage over that of a cyclone-type air filter? The engine is a 3.0L intercooled turbodiesel.
Thanks a lot!!
Thanks a lot!!
Originally Posted by IamaFan
just quick estimates of dimensions with a tape measure. If you need something more specific, someone who's pulled their box out can probably tell you. Hope this helps.
MTL_4runner : The filter on the 3rd gen TDI Surfs is located on the left and it's a cyclone-type filter. Locating it at right would increase the intake air temp because it would be located close to the turbo.
Dexter : Yes, the hood scoop is functional, it's for the intercooler which is mounted atop the engine.
justdifferentials
Just Differentials
09-17-2015 07:14 PM
Toyvana
07-29-2015 11:47 PM
1996, 2000, 34l, 3rd, 4runer, air, box, cyclon, dimensions, dimentions, filter, generation, hilux, measurements, surf, toyota, v6
