URD and Oregon DEQ (P0420)
Old 12-29-2009 | 06:06 PM
danielharro's Avatar
I have at 2000 4runner with CALI specs... and I have pulled P0420 code (cat insufficiency) and was wondering if I used the URD simulator if it would pass DEQ since their technically would be no error code of the ECU? Let me know what you gurus out their think....
Oh and now you are wondering if I have replaced any O2 sensors...This is what I have done to clear (P0130) error code.
Replaced both Oxygen sensors, TPS sensor and MAF sensor.....Now I have P0420.....I need to make sure the Oxygen sensor are OEM Denso brand with the correct serial numbers and I hope I won’t have to purchase a new Cat....ouch...
Any help would be much appreciated. I have read almost all other posts on this issue….
Daniel
Old 12-29-2009 | 06:07 PM
Daniel
Old 12-29-2009 | 07:48 PM
mt_goat's Avatar
The URD sim has rid me of all P0420 codes for the last 2 years. It will only get rid of p0420 and the rear O2 sensor must be in place and working. I don't know what a DEQ is though.
Old 12-29-2009 | 08:05 PM
Elton's Avatar
lol black font dont work with this black background
Old 12-29-2009 | 08:57 PM
DEQ= Department of Environmental Quality
How hard is it to install said URD sim? Any photos out their?
Old 04-20-2010 | 09:26 PM
99yota4's Avatar
any feedback on this? i'm getting p0420 codes as well. thanks
Old 04-20-2010 | 10:54 PM
JWaldz's Avatar
old thread but lol, Elton...Until I finally scrolled down and saw your post, I actually refreshed the page like 4 times thinkin' maybe something wasn't loading This does however feed me ideas for a new off topic thread, hmmmmm.....
ok, back to the original program
Old 04-22-2010 | 08:54 PM
TheDurk's Avatar
Just a heads up. URD was out-of-stock on the simulator for quite some time. Now a new model is available, and the site says installation is simplified. So older info in this regard may be inaccurate.
99Yota4, if you want useful feedback, post your truck/engine info (or put in sig) and what you have already tried. I cured my P0420 with a new rear sensor; I would certainly go that route if I had 75K or more on the existing sensor and no other code. No sense breaking laws in an emissions testing state if we don't have to.
Old 05-08-2010 | 06:56 AM
roadrnnr's Avatar
I installed a rear o2 simulator after I had the same code and replaced the rear o2 sensor. Unfortunately the NJ motor vehicle inspection said the rear sensor had disappeared. I was hoping it actually corrected the code. I called URD and triple checked everything including the o2 sensor #'s. I will probably have to install a new CAT.
Old 05-08-2010 | 07:15 AM
mt_goat's Avatar
So was this the newer URD design sim? What are the installation instructions for it? Did you solder all connections?
IntoTheVoid
10-24-2015 05:54 PM
dropzone
09-13-2015 12:18 PM
anniesball
09-07-2015 12:20 PM
anniesball
09-05-2015 09:45 AM
Snowheeler
08-21-2015 05:34 PM
