upgraded wire harness NOT WORKING
i just bought a heavy duty H4 wire harness from suvlights.com. I read the review from the toyota tech page and it seemed very easy to install. I grounded the wires, attached the new wire harness female plugs to the male part of the bulbs, and then attached the wire harness to the battery. I followed the wire up exactly. I even attached to fuses to the end of the wire harness. I put in 20a.
After everything was installed, I never got anything to happen. I didn't blow a fuse and i didn't get any light. I replaced the wire harness female plugs with the factory female plugs and the bulbs lite right up. Not sure what happened.
Is there anything that i can look for to see if the harness if working? I grounded the wires to the sides of the engine walls where there are pre-threaded holes. I have used the same holes for aux lights and the grounds worked fine.
Any help or suggestions would be great
suvlights are a good company. Did you try calling them?? It would make better sence than posting here. I would call rather than email. They have always been very helpful over the phone. Talk with Jen
I had a simliar porpblem when I first installed my HIDs from them. I called and they told me to reverse the connection. That worked for me but that was a different system but it was a simple fix....whew
TheManOutside
06-18-2015 03:32 PM
