Turning lights like on a Caddy....
Old 11-01-2005 | 10:17 PM
98LimitedCustomized's Avatar
For those of you who know, you know... everybody else: well on some Caddy's (had a 90 Deville that had them) when you turn on your blinker there is a like that shines where you'll be turning on that side. I found a guy who did the same someplace and it involved a capacitor, but with dark tint and ventvisors I find myself struggling to see where I'm about to turn. I've seen a few "bling bling" looking PIAA type lamps but I'm thinking of something a little more humble, useful, and cost effective. Anybody done this or have any ideas? I don't think our driving lamps have the capability to accomodate this...
Old 11-01-2005 | 10:24 PM
4x4Lamm's Avatar
I know Hella makes a kit that is a combo driving and turning light.
Lamm
Old 11-01-2005 | 10:25 PM
crappled's Avatar
there is a side light, on the side of the bumper... it's not really feasable *shrug*
and i'd think it would look like crap...
but....
to do this, you'd need to wire up a set of lights into the side of your chrome bumper. maybe even integrate them into the fender flares.
the wiring would be very simple though. there is a pos feed to the 'blinker' flasher relays, this is energized whenever your have your turn signal on. just wire ANOTHER relay off of the left, same for the right. use this relay to power the side lamps.
very easy to put down on paper, but timeconsuming online...
Old 11-01-2005 | 10:27 PM
crappled's Avatar
that kit barely lights up the side, really. it looks like a turn signal itself, lighting up the left side [of the bumper] not outwards like the caddy's (and taurus's, crown vics, marquis)
Old 11-01-2005 | 10:37 PM
I'm getting my TJM this week, this is something I want to look into... nothing like guessing where the road is in snow through a frosty tinted window. FYI I think the Caddy style I'm used to helps a ton. I can rig something up no doubt, also want to keep it from distracting other drivers as well.... If worst comes to worst I guess I can tuck some cheap fogs under there and run it off a switch...
Old 11-01-2005 | 10:50 PM
4x4Lamm's Avatar
You could use the hella logic module to run your lights of your choice in your desired location.
Lamm
Old 11-01-2005 | 11:07 PM
I saw those, but I'm a bit skeptical myself. Know of anybody who has them? I can just see them coming on every time you hit the brakes....
Old 11-02-2005 | 05:23 AM
Cebby's Avatar
My Maxima has these turning lights stock from the factory...
Old 11-05-2005 | 01:18 PM
node's Avatar
When you decide on what lights you want to use, I will give you the scematic for the circut Its easy and requires less than $10 in parts from radio shack and can handle about 600W of power.
ashersullivan88yota
01-18-2022 06:37 PM
Sleaker
08-26-2020 07:03 AM
rushw
07-18-2015 02:46 PM
Odin
07-15-2015 10:28 PM
Sandman
07-14-2015 01:36 PM
