Turn signals into DRL
Old 09-16-2006, 05:59 PM
Godzilla's Avatar
i got one question.....wheres the pics?!
Old 09-17-2006, 10:13 AM
jonb's Avatar
Well, here's a couple pics..not the best one but you get the idea.
First one shows both turn indicators acting as daytime running lights. They also work as normal when making turns.
Second pic shows where i mounted module under the hood. Hard to tell but it's just to the right of the fusebox in the picture (shiny black small cylinder). It's about the size of a large 35mm film canister, cylindrical, with about 7 wires to connect or splice.
Attached Thumbnails Turn signals into DRL-p1010070.jpg   Turn signals into DRL-p1010071.jpg
Old 09-17-2006, 12:33 PM
Godzilla's Avatar
Thats definitely pretty slick. must look good from a distance. How bright is it from futher away (what other drivers would see)?
Old 09-17-2006, 01:37 PM
Elton's Avatar
nice i see you went that route instead of the one i posted up still looks good
Old 09-17-2006, 08:08 PM
  #25
w99t4rweos's Avatar
Here's a easier way of wiring the front bumper park lights with 5 pin bosch relay, the only con would be, the bumper lights will flash alternatly of the T/S in the fenders. Each side will need it's own relay. This idea is from Duffdog.
You can do it with a simple 5 pin relay-- 30 to bulb, 87 to Park light +12v, 86 to gnd of blinker lights (since toyotas are switched ground) and 85 to +12 from running lights. 87a connects to nothing since you want the light to turn off when the blinker blinks it.
Old 11-24-2007, 05:53 AM
  #26
ewans's Avatar
Morning all,
Just wondering if anybody else has done this modification with the WebElectric DRL module that Jon used?.... any comments, good or bad?
I'm looking at using the same DRL module on a 2004 Tacoma, but I've been advised that burning the turn-signals continuously, which they were never intended to do, might not be a great plan.
Thanks in advance.
Ewan
ghostmoney
01-28-2018 11:42 AM
Shoua
13
05-22-2016 05:19 AM
Dennisx2
08-10-2015 06:48 AM
Dennisx2
08-04-2015 01:26 PM
PopsDad1
07-30-2015 02:21 PM
Quick Reply: Turn signals into DRL
