Tundra brakes on a 3rd Gen
#42
This is the 199mm conversion and so far I wouldn't see the need to go the the 231's for the type of driving I do. BTW, my truck is supercharged and I am not too light on the throttle
#43
Just a note that I reused the 4Runner anti rattle spring clips as they looked like they would be more effective than the tiny little springs that are used on the Tundra calipers.
#44
I did my Tundra upgrade a couple months ago as well!!
Hey bosco659 I like the Cross Drilled/slotted Rotors you upgraded too> I'll be putting a pair on my truck on the next brake job!!
Here's a couple of shots of my set-up>
I didn't get a chance to paint my rotors before the install>>
#45
I am looking to do the Tundra upgrade myself on my 1996 limited.
I do have a question, does anyone know if the 2000 Tundra calipers are the same ones on the 2002 Sequoia? They seem to come up with the same part number and use the same pads and rotors. I have a line on some 2002 Sequoia calipers and wanted to check to be sure first. Thanks
Ted
Ted
#46
Ted
Ted
#47
So the brakes on the ltd 4runners are bigger than the other models. And that's why the ltds come with 16's. Q: Are the brakes on the ltds smaller than the tundras'? And if so, by how much?
#48
The only difference is the Tundra rotor is a bit thicker and the Tundra pad is a different shape. You do not gain anymore stopping power over the stock 4Runner brakes; you only increase the heat capacity of the front brakes which is excellent if you're always towing heavy loads through urban or mountainous environments.
#49
This maybe worth while on my Tacoma assuming everything is the same as the 4 Runner. When bleeding your brakes is everyone using the Motive bleeder? Ive been hesitant to buy one only because of the sealing issue with cap that goes on the resivior. Which motive bleeder does everyone use? Thanks.
#50
#51
It's all what your after, but even the 4runner calipers should be an upgrade.
#53
For 3rd Gen 4Runners then ( I have the '97 Lmtd), is the following true;
-on stock 16" rims, I can swap in the tundra 199mm calipers with no grinding of the dust shield.
-I'm looking at ordering the Brembo blank rotor (part #25488 I think) or do I have to use a different rotor (ie would the tundrap caliper fit on a stock 16" rotor or does the rotor have to match up with a tundra part number (I'm confused about this).
-brake pads for the above---what about the akebono ceramics? Any issues with squealing etc...Unfortunately I can't get any Hawk pads where I am.
-is it a necessity to replace the brake lines after doing the above?
#54
No, a small amount of grinding may still be required on the dust shield and or calipers themselves (depending on what rim configuration you're going to be running)
-I'm looking at ordering the Brembo blank rotor (part #25488 I think) or do I have to use a different rotor (ie would the tundra caliper fit on a stock 16" rotor or does the rotor have to match up with a tundra part number (I'm confused about this).
Tundra rotors are the same regardless of the caliper size (231mm or 199mm), but the calipers will NOT work with a 4Runner rotor.
Akebono ceramics work great, get those if you can find them.
No.
No.
In red above.
#55
#58
I have 17" rims and want the best biggest OEM brakes i can fit. I'm assuming the newer Sequoia brakes are what I'm looking for right? Can someone give me the part numbers for the calipers and rotors I'd need?....
#60
