Tundra Brake Upgrade part/advise needed.
Hope someone can help... I upgraded my brakes last year to 2003 Tundra calipers (231mm) and I bent to destruction one of the piano wire brake-pad tension anti-rattle doohickies, so I did without it on that side. After a year of noise I finally can't stand it anymore and want to fix the problem I caused. Does anyone know where I can buy the wire "thing" without buying a set of pads? Or does anyone have a alternative way to prevent the dreadful rattle of the pads? Help appreciated. Unfortunatly I can't go to a dealer because I am in Japan and 1) Tundra is not sold here 2) Getting the parts guy to understand I have Tundra brakes on a 4-runner (HILUX) would be a translation nightmare.
Not the part number but if you enter one you could verify it is what you need: Toyota of Dallas
if your talking about the wire thing that looks like a "W"
i happen to bought mine a couple days ago
the part number for that for my 231mm set up is:
04967-0c010
Yes that is what it looks like. Thanks I'll try to use that number, but it did not work in the Toyota of Dallas link above. How did you get the number? BTW what made you go with 231mm vice the 199mm, and did you have to mod your wheels?
i like to go all out on my mods. Im running 17" tundra wheels
If that part number doesn't work.
This is what the little zip loc baggie said. on the label.
Description: Fitting Kit, DISC Brake FR
Come with 2, i'm pretty sure you only need one per side, But they're are sold in pairs.
correction: i made a typo on the part number sorry.
04947-0C010
those are all zero's by the way no "ohs" hahaha
04947-0C010
not a thing, when u get them could post a pic on the thread with them installed i kinda forgot how to put them back in hahah.
But yeah your welcome, im fed up with people with there freaking deckplate and exhuast questions
Here's the right way to install them:
http://www.ultimateyota.com/index.ph...18407#msg18407
The caliper W-spring always gets installed at the top of the caliper.
Are those the same as the FJ wheels?
If so do they fit ok on the 3rd gen 4runner and does that make it easier to do the big brake upgrade. I have a 96 limited that has warped front rotors and I want to add the FJ wheels when I do the brake upgrade.
Thanks.
Thanks.
06-01-2021 02:51 PM
94ofCanada
08-14-2015 07:37 AM
Suprarossa
07-06-2015 06:21 AM
