Tundra Bilstein shocks
Hi!
I will to change the actual stock shocks on my 1998 4WD and I am considering the Tundra TRD Bilstein 5100 Shocks:
Front Part Number: 24-188265
Rear Part Number: 24-100144
I have 4Runner 99 tall springs in the front and OME 906 springs on the rear, please let me know if the setup is ok. Thanks in advance.
For the rear shocks, you will need to replace the lower mount bushings with those for the 4Runner since the tundra bushing will not fit (the bushing hole is too small).
alternatively, you can use the rear shocks for the 4Runner:
24-249966
This one has the same extended and collapsed lengths as the tundra rear shock and also has the correct bushing size.
24-249966
Thanks, KZN185W!
24-249966
24-249966
JCBond
27
02-08-2016 05:00 AM
