Tube Bumper Design Begins...
"Thanks man, that's what I'm goin for the deer and elk here love to have parties in the road."
HAH! no joke at all...i find it an unusual day if i don't have to slam on the brakes at least twice on my run to and from town!
Next you need to use solidworks to do FEA on your design. You may be able to remove/relocate some material to improve your designs functionality. Set your frame mounts as stationary points and then apply forces to different locations on the bumper to see where there are high stress concentrations.
Also, if you add weld to the joints in solidworks and set the material of each component to the correct material that you plan to use, solidworks will also give you the exact weight.
Looking good so far, keep us updated.
#25
I got a couple more things to add tonight if I get em done I will post her up.
Thanks for all the comments guys!
#26
Alright well my first attempt at rendering. This stuff is pretty tricky to get the materials to show how they should. The lighting has to be just perfect. I can tell this whole game will take a long time to get actually good at, but here is a mock up of the powde rcoat. I also put the skid on and bent those lower arms into the upper ones. Cheers!
