Transmission problem, need help?????
My 1994 toyota 4runner auto tranny has sorta taken a dump. It hecka slips, so I thought no brainer, I need a new tranny. But the thing is it still works totally fine in 4wd low. So anyone who knows how these trannys are set up with the transfer case please help me out. I am pretty sure I need a new tranny. My only confusion is that it works in 4wd low with no slipping whatsoever. So anyone with knowledge that could point me in the right direction would be greatly appreciated.
Thank you...
Thank you...
Ya I checked the fluid and is fine, and I just replaced the fluid a couple months ago anyways. So you think its basically shot then??? Is there anything I can do to fix the problem or just buy a new tranny???
When you replaced the fluid, did you just drop the pan or did you get it completely flushed out?
If merely dropped the pan, there is still a lot of old, junky fluid in the torque converter that could be making your tranny perform poorly.
Cap'n
Cap'n
Originally Posted by YeloSub7
one more thing, are there kits to rebuild a tranny yourself? $$$ and where? how?
http://www.levelten.com/store/import...rts_toyota.htm
They both offer kits and manuals to DIY.
Poncho0206
07-10-2015 07:21 PM
madxman21
07-09-2015 11:26 AM
