Transmission not shifting
My brother has a 97 4runner 2wd auto and there is something wrong with the transmission. We pulled into work today and when i got in the drivers seat to go get some food i put it in R and did nothing. You can feel it drop into the proper gear, but there is nothing. I tried to push it backwards in N and it seemed like it was in P and wouldnt move. it is stuck at where we work right now and if anyone has any suggestions they would be greatly appreciated. O btw what is the name of the tranny. I have already looked on 4x4wire and it doesnt give the name for 3rd gens. Thanks again.
-Brandon
-Brandon
Well even with the tranny out of the truck sitting on the ground the shift lever will move it in and out of P and N. There is no power needed to do that, which is why I was thinking his shifter (inside the cab) is not moving the shift lever on the side of the tranny.
Electronic controls yes, vacuum no. But the electronics only control shifting after it's in D. Going from P to R to N etc is mechanical, controlled by the lever. And your 97 has an Aisin-Warner A340 series tranny, I think a 340H.
a few more things we found out today once we started messing with it; will definately shift into R but there is something in the tranny restricting it, when in N it will only go fowards and you cant push it backwards, when in D it will start in 3rd gear and will not go to any other gears except for OD. Even if you put it in L or 2 it will not do anything. We are gonna have to take it to a tranny shop and see what is up with it.
crammit442
7
11-29-2017 01:30 PM
