Transmission lines for external cooler?
So im doing some stuff ive been wanting to do a for a while finally found some time. The big one is my transmission. Im installing a external cooler I got out of a 1-ton dodge so im making it work. my question is what kind of lines do i need to get? Can i just use some fuel line or vacuum line or something else? Im going to be dropping the pan and changing the filter in there. Other then that im going to redo some wiring for my lights and things of that nature, then doing the bagel mod. Anything else i should look into?
So main question is what kind of line should i use to the trans cooler?
FS[PacSouthWest]: FS: 1988 4RUNNER FRAME 4X4 IFS Located in Lancaster Ca
4x4-runner
08-30-2015 08:55 AM
