Transmission cooler size question
Old 11-20-2002, 08:49 AM
Lurch's Avatar
Question Transmission cooler size question
In preparation for installing my supercharger, I'm planning on adding a transmission cooler, per the recommendations of others on this forum.
For reference, this site:
http://www.accessconnect.com/oilcoolers.htm
... has tranny coolers of various sizes. Just how big a cooler is necessary for my '99? It seems to me that the smaller the better for mounting, but it also has to be large enough to do the job.
Recommendations?
Old 11-20-2002, 09:35 AM
PhxTRDRunner's Avatar
I was referred to this site by another member...I'm going to follow his lead and get the 30k lb one..
http://www.bulkparts.com/MM001.ASP?pageno=1182
Old 11-20-2002, 09:54 AM
Senior Member
jacksonpt's Avatar
General consensus is the bigger the better. However, my TRD cooler is on the smaller side (about 8"x10"). Most people go with a significantly larger Hayden cooler.
Old 11-20-2002, 10:28 AM
Lurch's Avatar
OK, so there's no such thing as "too big" when it comes to tranny coolers, huh?
What about the larger ones blocking air into the radiator? Won't a large tranny cooler block a significant amount of cooling air to the radiator?
Old 11-20-2002, 10:33 AM
btw- the link I posted is to the Hayden transaver site.
Old 11-20-2002, 11:42 AM
pfdaxe's Avatar
Im running the extra heavy duty 30,000 lbs Hayden. It's size is not that much bigger and cools alot better. Go with Hayden. Same as TRD but about 1/3 of the price.
coffey50
07-28-2015 10:55 AM
mYnAmEiSmUd
07-20-2015 06:48 AM
jjrbus
07-17-2015 07:06 AM
Coreyr384
07-10-2015 11:13 AM
Snort
07-09-2015 03:58 PM
Quick Reply: Transmission cooler size question
