Transfer case and color of oil
Old 12-26-2006 | 06:55 PM
GhostriderTx's Avatar
I had the transfer case on my 2001 done at 20 and 40k at the dealer. I did it last week at 65k with 75w90 Valvoline dino. I kept hearing a whirring sound (only in 4whd) so I thought the case might be overfilled and drained about 4 ounces out. This oil was slightly gray after one week. I don't remember the color of the oil at 65K but don't think it was this gray. I hardly use the 4whd except in rain which hasn't happened much in Austin. Any thoughts on this or should I just drain it and refill again with a different brand.
Old 12-26-2006 | 07:15 PM
Elton's Avatar
Originally Posted by GhostriderTx
I hardly use the 4wd except in rain which hasn't happened much
i hope thats not on pavement
Old 12-27-2006 | 04:59 AM
Actually it is on pavement. The 2001 had a different 4WD system. It's basically AWD unless you lock it. I don't lock it on pavement
Old 12-27-2006 | 07:43 AM
rearviewmirror's Avatar
I think it's suppose to work like that but you can still feel it binding up if good traction is available, which it is most times when it rains.
Old 12-27-2006 | 09:57 AM
KZN185W's Avatar
Hi,
Without the Multi-Mode 4WD system, the transfer case is locked whenever you engage 4WD (4H or 4L). So you get driveline binding when you do that on hard surface/pavement.
HTH.
Old 12-27-2006 | 07:41 PM
The 2001 has multi mode. It also has a lock switch for the differential which would cause the binding. I have hte noice without engaging the switch
Old 12-27-2006 | 07:45 PM
Elton's Avatar
ahh i didn't know you had a 4runner my bad
09-04-2015 10:27 AM
Tykiller1994
08-10-2015 08:49 PM
tobylab
Diesel Swaps
07-17-2015 07:51 PM
88yodabasket
07-13-2015 02:32 PM
crashburnoveride
07-10-2015 07:39 AM
