Transfer Case/5spd Tranny Leak
Old 09-11-2005 | 01:55 PM
Under the '96 4x4 Runner last week lubing the drive lines and ran into something I didn't like. At the junction between the Transfer Case and 5sp Transmission there is a collection of gear oil that is fresh. I noticed that this junction has been gasketed by the orange FIPG material. Naturally, I checked the levels in the transfer case and transmission and they were OK.
So the big question: Tear it down and replace it? Or just keep a close watch on the levels??
How hard would it be to redo this joint??
Any and all advice is appreciated. Thanks.
Andrew
Old 09-11-2005 | 05:18 PM
kyle_22r's Avatar
not too bad, just put a tranny jack under the transmission, remove the crossmember and unbolt the transfer case. it's a little heavy(about 70lbs) to move around with but it's doable.
Old 09-11-2005 | 08:57 PM
4Crawler's Avatar
You could first check the bolts around the joint for tightness, especially around the leaking area.
Old 09-12-2005 | 06:44 AM
Bolt were confirmed tight. I'm kinda for the wait and watch method as I don't have time for it right now.
Thanks
Andrew
Dieselmann
02-19-2019 03:57 AM
yourrealdad
07-29-2015 12:08 PM
yourrealdad
07-21-2015 12:13 PM
Iceman4193
07-15-2015 05:48 PM
crashburnoveride
07-10-2015 07:39 AM
