Tranny cooler hose question
Sup guys... Last night, I finally got around to installing the tranny cooler lines... I purchased 4' of transmission cooler line and when I did the install, you guessed it... the size was too small, they gave me a 5/16"... I remember reading not to get the 5/16" one but totally forgot all about it when I purchased the line. Anyways, I was able to get the 5/16" hose to fit, not pushed all the way in but just enough to clamp them tight.
I went to the store to pick up some 3/8" hose today and they didn't have a 3/8" transmission cooler line. I ended up getting a 3/8" fuel line. I was wondering if the fuel line would be ok to use as a tranmission cooler line? Would the heat be too much for the fuel line? Should I just stick with the 5/16" one even though I barely have them on enough to clear the nipple with the clamp?
tia
Darrin
tia
Darrin
darn.... Thanks for the headsup bro... I was about to swap the lines... anyone know if Pepboys/Autozone/Napa carries the 3/8" transmission cooler hose? I went to Kragen and all they had was the 5/16".
the1998sr5
15
07-14-2020 09:35 PM
Iceman4193
07-15-2015 05:48 PM
