Old 03-30-2016, 10:24 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Toyota Tacoma Specifications & General Maintenance
Print Wikipost
Toyota Truck, 4Runner, Tundra Balljoint Failures
Old 02-08-2018 | 05:52 AM
  #81
stewartesq's Avatar
Wow....thank you for this info. I have a 1999 Toyota 4 Runner and would hate for this to happen.
Old 02-08-2018 | 11:57 AM
  #82
RAD4Runner's Avatar
YUP, Obviously Toyota did a poor job informing owners about this potentially deadly problem.
Old 02-08-2018 | 12:03 PM
  #83
stewartesq's Avatar
Well, I'm an attorney in Florida and wonder if a claim could exist under Florida's Deceptive and Unfair Trade Practices Act. From what I recall in reading this thread a few days ago, the dealerships are not helpful in fixing this problem; nor has any recall notice been issued. Let me know if I'm incorrect about that. I've been reading a lot of threads on here.
Old 02-20-2018 | 05:02 PM
  #84
sharrack's Avatar
The greatest lesson i've learned from this forum is when there are inherent toyota problems.....you just change them out.....end of subject.
Strawberry milkshake rad....changed
Ball joint issue.....changed
just do it!!
Old 02-20-2018 | 09:59 PM
  #85
stewartesq's Avatar
Cost
Ok, understood. Advice is to swap out ball joints. For a 3rd generation 1999 Toyota 4 Runner Limited Edition, what's the approximate global cost?
Old 12-05-2018 | 11:13 PM
  #86
RAD4Runner's Avatar
Found this on NHTSA site:
https://static.nhtsa.gov/odi/rcl/200...5V225-6542.pdf
"During the manufacturing process, there is a possibility that the surface of the ball portion of the Front Suspension Ball Joint in your vehicle may have been scratched. "
Statement above^^^ is B.S. It's an attempt to make the problem seem lighter, UNLESS all Toyota engineers missed the root cause which is the design that puts the LBJ under tension as shown below.
Scratches may cause looseness and play but if LBJ were under compression like other designs, it will not PULL APART.
Therefore, the recall should not only apply to certain years but to all vehicles where the LBJ is under tension as shown below.
File Type: pdf
matrad
08-26-2024 09:21 AM
rwh2toyota
13
06-27-2015 06:39 PM
toy89yota
06-24-2015 02:18 PM
88Toy
7
06-17-2015 10:40 AM
2wdtundra
06-17-2015 02:41 AM
