Towing Disappointment
When I spoke with the local U-Haul rep about renting a car carrier, I was surprised to find out that my '02 4Runner (4WD) with factory "Tow Package" is NOT rated (according to U-Haul data) to pull their carrier and my '72 Chevelle. I've pulled trailers carrying up to 4 Harleys and never gave it a second thought - WHAT A DISAPPOINTMENT. Anyone know of a kit that can add capacity?
The towing capacity of a 3rd gen is 5000 lbs, and I would think a 72 Chevelle and a car carrier is definitely over that limit. A 72 Chevelle by itself is probably close. There is no way to increase the towing capacity of a vehicle, without an engine, transmission, axle and brake swap.
Sounds like it's time for a Tundra.
Are you kidding? come to Belize and see what these guys tow behind thier 4cyl's and 6cyl's.
I've seen a 4cyl 2wd pick-up towing so much that another 100lb's would remove the front wheels from the ground! and the motors have 400k + miles and they still do it. There are no limits
Yes, in BELIZE. They probably don't have such a problem with state and federal DOT regulations, road maintenance and the USA's affinity for lawsuits. U-Haul is just a company that practices CYA to a fault. I, too, have towed things that were much too heavy for my /94 with no ill effects, but I didn't rent from U-Haul, and had to sign a piece of paper that said I wouldn't blame anyone but myself for damage to my vehicle. Kind of silly, but I see where they are coming from.
UHaul has been pretty strict with this sort of stuff.
They won't lend me a car caddy with a Crew cab TUNDRA. Nope, I couldn't even rent a damn car trailer! They said that the Tundra had enough power, but, not enough weight. Probably the same with the 4runner... They are denying you because of weight restrictions./
http://www.consumeraffairs.com/news04/uhaul_ford.html
...so I think they probably let towing infractions slide just a bit.
I went to pick up a Supra front clip (ie. front half of a car) and Uhaul wouldnt let me rent a car trailer because a "half car" is not in thier computer system, we were using a 03 F350........so we went to the next closest Uhaul and told them we were towing a 82 Toyota Tercel........no problem!!!
Hmmm weird..they rented me one with no problems..hehehe
yeah uhaul suck. they wouldnt rent me a tiny storage trailer so i could move all my stuff from vegas to here. they said my truck doesnt have enuf power. if thats true, then how did i tow a 91 camaro on a car dolly for like 90 miles at 55? uhaul sucks!
That's what we've always done.....tell them you have a full size truck and you are going to be towing a Ford Escort or something small and gay like that. Of course this doesn't work once you've already been in there and told them what you really drive and what you really want to tow. At this point you'll need to send someone else to rent it for you, or go to a different location. Or some other local equipment rental place.
