Tires Cupping - Uneven Wear
Hello,
I have a set of Goodyear MTR's on my 99 4unner with an OME lift front and back. I have noticed that the tires are wearing unevenly - wearing more on the outside and unevenly (cupping?) I had an alignment after I installed the lift as well as a few (3-4) due to knocking it out while wheeling. I have had some trouble balancing the tires but don't know if this could cause the problem. Any ideas on why my tires are wearing like this or what I can do to correct it? Thanks.
Tire pressure is good, Alignment is (or should be) good, Balancing is a little off (vibrates around 60 mph). I need new tires and want to figure this out before I get them and ruin them. Any ideas??
Originally Posted by Greedy
I ruled that out as well as I installed OME shocks about 2 1/2 years ago - or about 35,000 miles ago.
Cupping is shocks, air, or alignment. Balence issues would have huge patches missing or worn down iirc.
[QUOTE=Bumpin' Yota]if you push the bumper down then rapidly lift it up cna you make the shocks make any noises? If the shocks make any noise they are no good...
What kind of noise would that be?
Originally Posted by surf4runner
Originally Posted by toddowaddo
I did read that noob, that's why I wanted clarification on "any noise". If you go out, bounce your vehicle up and down it will make a noise. I've got new bilsteins on my Mercedes, they make a noise when you bounce them up and down. My 4runner has Rancho's that are less than a year old, they also make a noise. The fluid passing internally when the shock cycles will make noise. Have a great day.
my mt/r's wore a little unevenly due to balancing issues.... theyre tough tires to balance. i have since had to swap 2 of those badly worn tires out due to vandalism on them (one stabbed, other just chopped at).. and have had NO issues since. perfect balance.
i went wheeling a week or so ago and knocked my alignment out so bad that my steering wheel was pointed at like 10 oclock to go straight
got it realigned and it runs beautifully right now.
"And and dont let your neighbor see you pushing down and then lifting up repeatedly on your bumper, they might just think you went off the deep end...LOL"
You're right about that. I was trying to duplicate a "squeak" I heard one time. I was out there rocking it back and forth when I had that feeling I was being watched. I was... felt stupid... went back inside.
How frequently do you rotate them? A mudder/aggressive tread tire like MTRs should be rotate more frequently than an all terrain especially considering the natural toe-in on a 4 wheel drive vehicle. I try to do mine every 4k or less.
Just an opinion and I'm usually wrong...
Originally Posted by mudnsnow
From what i have heard shocks are only good for about 35000 to 45000 Miles, so your shocks are probably on their last leg
Thanks for the help. I had a feeling that I wasn't rotating them enuf, probably about 2 times over the last 35,000 miles. Regardless, these are worn out and I will be ordering some silent armors, bfg at, or nitto terra grapplers before winter hits full on. I'll be sure to keep a close eye on the pressure, alignment and rotation for this set and see if it helps. Thanks again!!
Blamalam
03-12-2022 07:34 AM
89fourrunner
02-17-2016 06:52 AM
Jcrawl94
10
10-24-2015 04:34 PM
FS[NorAtl]: some RC stuff crawler and racer
akaphilly
07-09-2015 02:34 PM
