Tire size question
Tire size question
ok I am going with the BFG AT's but I had a question about the sizes, I have a 17x8 on, I was going with the 31x10.5R15. These should fit no problem right? also what is the difference between something like the 285/75R16 and the 265/75/R16?
If you want 31X10.5R15 then you will have to get either 15X7 or 15X8 rims. 285 versus 265 means not only a wider tire but a taller tire also. both by at least 1 inch. The 16 on the end of the tire size means you need a 16 inch rim. Hopes this helps.
Actually they are 16x8's... damn too early in the morning! haha.so something like the 31x10.5R15 means I need a 15 in rim right? is that the max rim size? or does it mean it has to be at least a 15?
djpg2000
11-11-2020 04:56 AM
09-04-2015 09:27 AM
coffey50
07-28-2015 10:55 AM
