Timing belt estimates.
From this page - click toyota at top and go to the third page
http://www.jerrystoyota.com/ou/balti...age=s_specials
I doubt it will help you because it's a dealer coupon and not a "toyota" coupon
Rook
Rook
I started to change my 98 4runner at 90,000 miles, got it down to taking the crank pulley bolt off, and couldn't. That thing is on there, my impact didn't have anything for it. Put it back together and took it to a guy I know and I supplied the parts and he changed it for $165 including some of that expensive red antifreeze. He got the crank bolt out with a small ($500) Matco gun, and he didn't even have to take the radiator out.
A timing belt change (without doing the water pump, just includes the belt for parts ciost) should be about $250-300 (closer to $450-500 including the W/P, just the belt and W/P for parts cost). If you need a tensioner, idler or cam/crank seals those parts will add to the cost of the job.
#25
tb and wp
my pump was leaking and my 98 had 145km on it. it was cold and so with xmas travelling coming up i didn't want to get stranded. the stealer charged me $690.00 cdn total, taxes enviro and fluids. stiff enough i know but all in all a good experience. the reason i used the stealership is because i wanted to maintain the value of my truck in the event of someone elses bad driving crashing me up or in 3 yrs when i sell to buy an fj crusier. good value with yoda's and oem parts.
