Timing belt change: 99 4Runner 3.4L
Old 09-07-2004 | 07:22 AM
AJatx's Avatar
Do you have to remove the AC compressor in order to remove the timing belt tensioner?
I tried removing one of the bolts on the tensioner and it's starting to strip. So, I'm removing the bracket in order to get a better angle at it.
Also, do you remove the backplate near the tranny/oil pan in order to jam the torque converter so you can untorque/torque the main front hub/pulley bolt?
J
Old 09-07-2004 | 09:00 AM
MTL_4runner's Avatar
Yes, I did for the AC bracket and it came out fine.
I rented a chain wrench and used it around the crank pulley (wrap an old belt around to protect the pulley grooves).
voiddweller
19
05-02-2016 10:10 PM
vasinvictor
01-20-2016 01:39 PM
layifioren
10
07-06-2015 03:26 PM
B. Graves
07-03-2015 05:10 AM
infinityisfive
06-16-2015 07:51 PM
