Timing belt at 7 years or 90K?
Old 12-31-2007 | 05:46 PM
GhostriderTx's Avatar
My 2001 has 75K but I bought it in 2000. Any thoughts on doing the timing belt early at 75K since it has seven years?
Old 12-31-2007 | 05:58 PM
One_96TR4's Avatar
It won't hurt anything, I say if you have the cash and want to do it go for it. I don't think it's necessary though.
Old 12-31-2007 | 06:14 PM
ciscojay's Avatar
I'd get it done just because of the age. You're gonna have to do it eventually. FYI I just passed 173k miles and did my second waterpump/timing belt service last week. Saw the belt from the first change and it looked like it was on it's way out. I saw a few barely visible cracks on the outside edges of the belt about 1/4" in length. you couldn't really see them unless you folded the belt a bit and were really looking for it. I'm just glad I got it done...I was told if you live in an area like mine that can get really cold the belt is more susceptible to cracking and eventually failing as opposed to more temperate environments. But, a 7 year belt sounds iffy to me.
Old 12-31-2007 | 06:56 PM
frodin1's Avatar
I was wondering the same thing on my rig. 2000 and I just flipped 65K. At this rate it's going to take a quite a few more years for me to hit 90K. I'm thinking I don't want to risk it.
Old 12-31-2007 | 07:10 PM
neoworm0's Avatar
is the 3.4 an interference motor. If it isn't just run it till you're at 90k.
86tuning's Avatar
If you use a genuine timing belt, and change the waterpump, thermostat and both bearings, you're good to go for at least 90k. I've done so many of them at ~200,000km (125k) to know that 90k (150,000km) intervals are actually conservative with the 3.4L engines.
YMMV
Old 12-31-2007 | 07:21 PM
86tuning's Avatar
ps, almost all Toyota t-belt equipped engines are non interference. Almost all chain-drive engines are interference.
Notable exceptions for T-belt engines:
jdm engines in some uber cars (95+ 4AGE, 3SGE, etc)
recent 3.3L sienna/camry/highlander/ES330/RX330 etc
Old 12-31-2007 | 08:47 PM
instigator's Avatar
got 220,000 on original belt and water pump. knocking on wood right now
Old 12-31-2007 | 09:03 PM
rearviewmirror's Avatar
My 2000 is at 57k miles. I'm contemplating having it changed. Since it's not actually an interference engine I'm not that worried about. I just had the timing belt changed on my 1998 Honda Prelude with only 40k miles because of the age of the belt and tensioner. The difference is that on the Prelude a broken timing belt means a new engine.
https://www.yotatech.com/forums/f2/c...change-133357/
Old 12-31-2007 | 09:05 PM
CASTAIC 4RUNNER's Avatar
90,000 miles or 7 years .. just got mine done today by toyota. and water pump, rear axle seal, ALL fluids and fuel filter
Old 01-01-2008 | 10:07 AM
MTL_4runner's Avatar
You're definately playing with fire there.
Old 01-02-2008 | 02:53 PM
Mulkey's Avatar
I have 139K on my 2000 Limited. About to change the water pump/belts pretty soon.
06-01-2021 02:51 PM
elwood73
07-05-2015 08:07 AM
CJ94yota
07-03-2015 11:14 PM
