Throttle Body Cleanout Write-up (w/ PICS)
Old 01-06-2010 | 06:47 PM
rimpainter.com's Avatar
Originally Posted by zcruiser
Your site says 'out of stock'
Wow, thank you for letting me know! I don't check my PayPal buttons every day and the PayPal inventory tracker was set at "0" thanks to the last time I sold out and never reset.
You, my friend, get a free O Gasket for letting me know. PM me with your address and I'll send one out to you.
Thanks again.
Don't hack up your OE metal gasket with a Dremel, go with a perfect fit gasket and material that won't transfer heat like metal will, the O Gasket. It's a CARBON mixture by the way, not paper.
Old 08-21-2012 | 10:42 AM
02t4r's Avatar
Awesome writeup, I'll be doing this soon. I have the same throttle body as you, which doesn't have an EGR. One question, I pulled the vacuum hose off of the TB today while the engine was running, and I was surprised to learn the airflow wasn't pulling into the throttle body from the hose as I thought it would. It was actually pulling AWAY from the throttle body, into the hose, which leads into the back of the block. What hose is this?
Old 08-21-2012 | 10:53 AM
stir_fry_boy's Avatar
Not sure what it does. There is a vacuum hose for the heater control I believe? I just unhook everything while the engine is off and cold and put everything back together. Hard to work on a hot engine with hot coolant (running through air idle control)
Big Little Bear
230
11-13-2023 12:42 PM
fountain
02-28-2016 11:13 AM
nerofiend
09-22-2015 08:17 AM
bobjohnson2121
09-17-2015 09:07 AM
Badfish740
09-04-2015 05:21 AM
