Throttle Body
Old 01-06-2005 | 10:25 PM
98_YOTA's Avatar
Talking Throttle Body
Has anyone ever installed throttle body spacers or bigger bore throttle bodies in their toyota? If so was there any noticable performance gains? I can read so much, but would rather get other peoples opinions thanks!
Old 01-06-2005 | 10:34 PM
superjoe83's Avatar
I'm not sure on the larger TB's, but the spacers are a waste of money
Old 01-06-2005 | 10:41 PM
98_YOTA's Avatar
cool thanks! I guess I'll save my money and buy a front bumper!!!
Old 01-06-2005 | 10:52 PM
bike4miles's Avatar
I would sugest a cone intake to get a little extra power. They are cheep ($10 to $50) and they make a noticable diference, esspecially when it is cold outside.
Old 01-07-2005 | 11:07 AM
midiwall's Avatar
There're a number of threads here asking about TB spacers... This is the latest one:
https://www.yotatech.com/forums/f2/poweraid-throttle-body-spacer-48213/
There's also a lot of info about intakes... Searching for "deckplate", "isr", "intake silencer", "mit", or "airaid" will get you started.
The short form is that getting more air into the intake is a good thing. It's also been shown for performance to smooth out the path that the air travels in getting to the TB.
But... you have to make a choice. The cone intakes are okay for street, but will kill you in the dirt and mud. You can get similar performance and better protection for your engine by going with an Amsoil filter in the stock airbox, and then opening up the front of the airbox with the "deckplate mod". There are couple of articles in the Tech Section.
Have fun!
Old 01-07-2005 | 11:18 AM
rimpainter.com's Avatar
I bored out my TB. Try a search on "TB bore." The pics should still be up.
Oh, get one of my TB O-gaskets too while you are at it. I only have two left. Click on my sig for more info.
Old 01-07-2005 | 12:13 PM
Bigkahuna808's Avatar
Along time ago before I found my way on to the boards I bought one. Its kinda worthless, and just sounds cool. When you get on the gas and let off there a wooosh sound. Kinda like a generic turbo or super charger. But if your looking performance look somewhere else. Im gonna get rid of mine soon as I buy that bored out throttle body from Downey,
Old 01-07-2005 | 01:06 PM
midiwall's Avatar
... ummm, $300 can buy you a LOT of Dremel tools with bits. Like Christian (and others here), I bored out my own TB. I can't say that it did a lot, but it's cool to know that I did it.
It's painfully easy to do... Christian's original thread is here:
https://www.yotatech.com/forums/f2/new-mod-3-4l-tb-bore-mod-o-gasket-mod-pcv-breather-mod-pics-16366/
Old 01-07-2005 | 02:26 PM
For me now that Im back in college time is crutial. I would love to buy a dremel and do it myself, but im trying to fix a problome with starting. I go to school full time and work full time. I hardly have time to sit and do things. I havent even washed my truck in months. But I do have a appointment to detail it next week.
Old 01-07-2005 | 02:40 PM
midiwall's Avatar
For me now that Im back in college time is crutial. I would love to buy a dremel and do it myself, but im trying to fix a problem with starting. I go to school full time and work full time. I hardly have time to sit and do things. I havent even washed my truck in months. But I do have a appointment to detail it next week.
I got two comments... I ain't trying to be a smart arse, just pointing stuff out.
- You go do it yourself in less time than you'll be waiting for the detailing.
- Are you looking towards a larger bore TB to help your starting issues? If so, you should fix the issues first before adding the TB. I don't see anything in your sig that would suggest TB issues... What're the symptoms?
Old 01-07-2005 | 05:07 PM
No the throttle body is no way realted to my starting issue. The issuse as the the starting relates to my truck no wanting to turn over when the engine has been run for a while. It is stuck in open loop acording to the scan. I replaced the o2 sensors. And that did not help, it either has to be the temperature sensor or the coolant temp sesnor. Or some sort of sensor.
As for the detail, I drop the truck off before I go to work, and its waiting for me when I get off. So it works out pretty well.
Old 01-07-2005 | 05:22 PM
midiwall's Avatar
Ahh... okay. the way I read the other post, it sounded like you were gonna replace the TB to fix a starting problem. my bad.
Old 01-07-2005 | 05:23 PM
Nah, I only wish that was the simple fix I need. Thanks for concern.
Blamalam
03-12-2022 08:34 AM
Blamalam
08-16-2015 01:29 PM
mtc1105
08-04-2015 09:06 PM
bighaydn
08-04-2015 08:17 PM
greenbuggy
3.4 Swaps
07-23-2015 12:51 PM
