Thermostat changing
Thermostat changing
This is kinda a stupid question but do you have to remove all the coolant when ya change the thermostat or can ya just take a little out until its below the thermo. level and then change it. Dont really want to have to take it all out if i dont have to. thanks.
You don't have to remove it all. Hell, on my truck, I just remove the thermo and let the coolant spill out when I pop the elbow off the thermo housing.
Hope this helps.
Dr. Z
Hope this helps.
Dr. Z
You don't have to remove all the coolant. But, it's less messy if you put a bucket under the valve on the radiator and unscrew the valve. I just drained mine completely and replaced it with new 50/50 coolant/water. This way, you experience less of that "burning coolant" smell. Well, maybe you like that sorta thing...
to change radiator fluid do you screw the wingnut at the bottom of the radiator in or out. I'm trying to learn how to do maintenance on my rig so im new at this stuff. thanks.
Out, or counterclockwise. It is not designed to come all the way out of the radiator, so once you get a good flow going you have opened it enough. Also, take off the radiator cap before you do this, so it drains faster.
So I better ask where this thermostat is actually located, so when I get mine, I can replace this thing with ease. Anyone have pictures or details on how to do this swap?
Chris
Chris
Chris,
The T-Stat housing is located right where the Lower Radiator Hose attaches to the Engine. It is held in place by (3) 12mm bolts. You'll need a short extension and flex-head ratchet wouldn't be a bad idea either.
I don't have any pics, but it's really easy to find and to R&R.
Hope this helps.
Dr. Z
Hope this helps.
Dr. Z
Blamalam
03-12-2022 07:34 AM
the1998sr5
15
07-14-2020 08:35 PM
the1998sr5
27
11-17-2015 09:30 AM
Poncho0206
07-10-2015 06:21 PM
