Is there a solution to uneven tire wear on 4runner ?
Hi, I noticed that my 4 tires on my 4runner have uneven tire wear just today. I am talking about the part of the tire that contact directly on the ground. The outer part of the tire is weared away excessive while the inner part is still in good shape. This applies to all 4 tires (front and back). A front end alignment is done about 6 months ago and it still won't correct the tire wear problem. I was wondering if this uneven tire wear problem can be fixed by taking the tire off the rim and flip it around so that the good part is facing outward and the weared part is facing inward ? or they must be replaced with new tires which can be expensive ? I would appreciate if you can throw in some comments or suggestions.
Originally Posted by Silver_Truck
sounds like you have way to much positive camber...time for an alignment...but first go through everything in your suspension and make sure its not bent. check bushings too
06-01-2021 02:51 PM
skoti89
07-08-2015 01:05 AM
