Teflon Coated Wheels!
They look cool but I wonder if they are like a frying pan and scratch easily?
I saw a pic in a current 4x4 mag- black/black Avalanche with the AE Mohave (above) and it looked awesome (the wheels I mean)
Re: Teflon Coated Wheels!
Just spray them with some PAM before you wheel!
Re: Re: Teflon Coated Wheels!
Originally posted by waskillywabbit
How do you get scratches at the mall? j/k
Why bother with a teflon pan if you're going to use PAM on it, anyway? Isn't the whole point of teflon that you don't need oil because crap doesn't stick to it? (PS I hate teflon, butter = flavor)
I don't think I would want "Teflon" written on my wheels, but maybe my wife would. j/k
What is it with Teflon showing up in places it doesn't belong?
Perhaps these wheels keep you from burning rubber....
before teflon coating
after teflon coating
before cleaning
after spraying with water-nothing sticks...
...even on the inside..
coated engine block- now that would make mudding easy to clean!
before cleaning
Originally Posted by SLC Punk
Wow I actually like the looks of those.
Anyone know if teflon will flake off when exposed to road salt?
You cook with salt so I think teflon would be fine-seems like it protects against things like salt...
It can be etched with an acid but where are you going to get into that stuff up to your wheels.
It would flake off if salt got underneath tho.
hehe, nothing new..... I've been coating my stuff for over 20 years now. This is the company you can purchase the product needed for the DYI:
http://www.kgcoatings.com/
GunKote it the product
How well does it actually hold up?
I've done several of my rifles with this coating along with aluminum exaust pipes for dirt bikes.
Once you apply the product you need to bake it in a oven to cure it. The stuff is really tough and resist abrasion, the military has caught on and uses it on many of their hardware.
I coated a tuned pipe on my RC plane and when it crashed hard into the ground the pipe was scuffed but no scrapes through the coating.
I could take a few photo's of the rifles that I coated, but you can't really tell the difference between that and the original finish. It would be easier to show in real life how tough the stuff is. Last time I purchased the product, they had a minimum of 4 1 gallon cans. I sold 3 of them to friends and still have a half gallon somewhere in my garage.
Bruce,
Is that stuff teflon then? The same as what AR is using for the wheels?
Sounds really cool.
Does it stick to metal or do you primer with something first?
Looks like the product sheet recommends sandblasting for most metals, pre-heat material to 120 and then bake for an hour at 300 - 325F after painting.
16oz for $26 and 1 gallon for $144
Probably not for vehicle exteriors, but might work for a lot of other things...
they have a few colors too, gold, red, royal blue, clear, OD green, gray tan, white
sounds like really cool stuff!
You apply it directly to bare metal, I fabricated a sheetmetal oven and used a propane heater to bake the parts. You don't want to use the oven in your house, it'll stink up the entire place, I know did that once....oops
I remember paying aprox $50 a gallon, but that was a few years back.
