Tacoma, 4runner headers
Old 04-25-2005 | 03:11 AM
lebeau's Avatar
What are the differance? Is it just the cross over pipe? I have a set for a Tacoma 3.4 but my brother wants to put them on his 4Runner and since he lives in another state I can't compare the two.
Old 04-25-2005 | 07:30 AM
rimpainter.com's Avatar
Could you please clarify your question(s)? It is kind of hard to figure out exactly what you want to know.
Old 04-25-2005 | 07:46 AM
lebeau's Avatar
O.K. I have a set of headers for a Tacoma and want to know if they will fit on a 4Runner.
Old 04-25-2005 | 08:07 AM
kevin444's Avatar
I wouldnt see why not? After all it is pretty much the same vehicle.
Old 04-25-2005 | 10:21 AM
lebeau's Avatar
Thats what I was thinking and most of the sites I went on don't differentiate between the two. I just wanted to know for sure before I sent them to him.
Old 04-25-2005 | 10:55 AM
The only differences that I know of are the downpipe flange for the cat, and the EGR system. Neither of which should affect you because you will have to cut and weld anyway on the 4Runner. The EGR bung will just get plugged off using your existing blocking plate.
I highly advise piecing everything together before you undertake this hellish install. Once you cut that crossover pipe, there is no turning back (unless you want to pull the motor).
Old 04-25-2005 | 01:06 PM
lebeau's Avatar
Yeah Iv'e put on two sets already so I'm sure I will wind up putting these on too. It's pretty easy after you have done at least one. The easiest way to get the crossover out is to lossen up the tranny mount and jack it up it will give you a little more room.
Old 04-25-2005 | 01:40 PM
Well even with a 1" BL I couldn't salvage mine. I just cut that sucker off - 2 hours later.
smthwsn357
05-01-2024 08:28 AM
09-04-2015 10:27 AM
TokyoD23
07-12-2015 07:01 AM
Cplmike
07-08-2015 09:47 PM
AaronM
07-08-2015 08:15 PM
