Taco spring swap
Taco spring swap
Has anyone here retrofitted Tacoma springs onto an 89-95 pickup? I have an opportunity to get some cheap Tacoma 2" lift springs from a 2003 and was wondering if it was sorth it...from what I've heard up to 96 has the same springs and 97 and later have longer ones. Thanks
i believe the taco springs are longer than what you have right now, you will have to do some measuring to see if they will fit, mainly center bolt to either end of the pack to see where to relocate your stock hanger, if the taco springs are longer
I'm not a mechanical engineer but I would definately relocate the rear shackle hanger to accomodate the longer springs. Just getting a longer shackle won't do anything but limit your up-travel as well as effect the axle wrap. It would probably take a competent welder no more than 30 min. for both sides. lol
if you jsut toss in the longer springs and dont relocate the front hangar or the rear shackle mount, your axle will most likely be set further back and will not fit in your wheelwell, the axle sits in the middle of the spring usually, and if you dont relocate where the middle is, then it wont be centered in the wheelwell
Flying91
45
04-11-2024 05:39 PM
ripp96
07-25-2015 03:32 PM
