Taco Rear axle on 4-runner?
Originally Posted by snwbdr
so I got a taco TRD rear end w/ E-locker.....what all would be involved to make it work on a 96 4-runner?
thanks for the info....I was actually thinkin' about just swappin' the axles...but as I understand it, the 4-runner uses coilovers and not leafsprings? I figured the wiring n stuff like that...just wondering if it'll bolt up...like are they the same width and everything...and what about the brakes...are the 4-runners disc brakes in the rear?
Oh yeah, if the 4Runner has abs, the axle will need that too, unless you just swap the thirds. Swapping the thirds and modifying the 4Runner housing is probably the easier way to go.
Originally Posted by alltheway
Why are you putting a E-Locker in the rear...why don't you just but a set of Detroit Lockers and be done with it.
I thought that the taco axles and 4runner axles were the same 60" length!!! WTF???
Originally Posted by bamachem
the taco axle is wider by about 2" IIRC. just do the third swap and don't do the whole thing unless you do your homework.
snwbdr
imho, better to retrofit the locker into your existing housing. or buy a bare axle that used to have a locker in it and then swap the internal parts. search "e-locker retrofit".
but better how? installation is straightforward like you mentioned, but they have a lot of cons like non selectable, clicking, always on, barking around corners if you don't have good control on corners to name a few. don't get me wrong...they are not bad, but be careful when you offer a definitive, subjective opinion like "better".
Yeah but a Detroit will be a lot easier to install and a lot better than an e-locker.
Yeah - I agree on the locker thing. On my 2 trucks I have 1 e-locker, 1 ARB, and 1 lunchbox. The powertrax locker works, but it is a DISTANT 3rd to the other 2 IMO. It is harsh, chirpy, and sometimes slightly unpredictable. I will never buy another. I will save and get a selectable.
If it helps me answer my questions, I don't mind at all. I search, I find, and I get updated...
Originally Posted by SC4Runner
Anyone realize that this thread is 2 years old?!
Taco axles and 4runner axles are supposed to be the same width... or so I thought.
jerusry
10-19-2015 05:28 PM
FS[GreatLakes]: Toyota collection part out
88sasturbotoy
08-11-2015 01:56 AM
cgilley
07-15-2015 03:32 AM
