Sweet rigs :)
#1884
Hello Folks, just joined the forum hoping to find solution and not get rid of my beloved vehicle. I own a 99 -SR5, the 4 wheel https://www.yotatech.com/# light is engaged and I cannot shift out off 4
thought. The vehicle is drivable but feels like it is stuck in 4-LoW because the engine is revving 30 rpms at 20 https://www.yotatech.com/#. I feel the truck shifting into first and second gears but will not shift any higher when accelerating.
I had my mechanically inclined brother in law remove the shaft leading to transfer case believing if stuck in 4 could manually disengage the front wheels from 4 wheel drive mode and be able to drive in rear wheel drive only.
This did not solve the problem but made me wonder if I have a problem with the
Thanks in advance,
Trunner4
<a href="<A class="vglnk" href="http://ad.doubleclick.net/jump/yotatech.tmus/category;kw=firstpost;kw=1stpost;category=Toyota_S UV_Truck_Tech__Newbie_Tech_Section;topic=99%204run ner%20fix%20or%20not%20fix%20seems%20stuck%20in%20 4%20lo;sz=300x250;ord=123456789" rel="nofollow"><SPAN>http</SPAN><SPAN>://</SPAN><SPAN>ad</SPAN><SPAN>.</SPAN><SPAN>doubleclick</SPAN><SPAN>.</SPAN><SPAN>net</SPAN><SPAN>/</SPAN><SPAN>jump</SPAN><SPAN>/</SPAN><SPAN>yotatech</SPAN><SPAN>.</SPAN><SPAN>tmus</SPAN><SPAN>/</SPAN><SPAN>category</SPAN><SPAN>;</SPAN><SPAN>kw</SPAN><SPAN>=</SPAN><SPAN>firstpost</SPAN><SPAN>;</SPAN><SPAN>kw</SPAN><SPAN>=</SPAN><SPAN>1stpost</SPAN><SPAN>;</SPAN><SPAN>category</SPAN><SPAN>=</SPAN><SPAN>Toyota</SPAN><SPAN>_</SPAN><SPAN>SUV</SPAN><SPAN>_</SPAN><SPAN>Truck</SPAN><SPAN>_</SPAN><SPAN>Tech</SPAN><SPAN>__</SPAN><SPAN>Newbie</SPAN><SPAN>_</SPAN><SPAN>Tech</SPAN><SPAN>_</SPAN><SPAN>Section</SPAN><SPAN>;</SPAN><SPAN>topic</SPAN><SPAN>=</SPAN><SPAN>99</SPAN><SPAN>%</SPAN><SPAN>204runner</SPAN><SPAN>%</SPAN><SPAN>20fix</SPAN><SPAN>%</SPAN><SPAN>20or</SPAN><SPAN>%</SPAN><SPAN>20not</SPAN><SPAN>%</SPAN><SPAN>20fix</SPAN><SPAN>%</SPAN><SPAN>20seems</SPAN><SPAN>%</SPAN><SPAN>20stuck</SPAN><SPAN>%</SPAN><SPAN>20in</SPAN><SPAN>%</SPAN><SPAN>204</SPAN><SPAN>%</SPAN><SPAN>20lo</SPAN><SPAN>;</SPAN><SPAN>sz</SPAN><SPAN>=</SPAN><SPAN>300x250</SPAN><SPAN>;</SPAN><SPAN>ord</SPAN><SPAN>=</SPAN><SPAN>123456789</SPAN></A>?" target="_blank" ><img src="<A class="vglnk" href="http://ad.doubleclick.net/ad/yotatech.tmus/category;kw=firstpost;kw=1stpost;category=Toyota_S UV_Truck_Tech__Newbie_Tech_Section;topic=99%204run ner%20fix%20or%20not%20fix%20seems%20stuck%20in%20 4%20lo;sz=300x250;ord=123456789" rel="nofollow"><SPAN>http</SPAN><SPAN>://</SPAN><SPAN>ad</SPAN><SPAN>.</SPAN><SPAN>doubleclick</SPAN><SPAN>.</SPAN><SPAN>net</SPAN><SPAN>/</SPAN><SPAN>ad</SPAN><SPAN>/</SPAN><SPAN>yotatech</SPAN><SPAN>.</SPAN><SPAN>tmus</SPAN><SPAN>/</SPAN><SPAN>category</SPAN><SPAN>;</SPAN><SPAN>kw</SPAN><SPAN>=</SPAN><SPAN>firstpost</SPAN><SPAN>;</SPAN><SPAN>kw</SPAN><SPAN>=</SPAN><SPAN>1stpost</SPAN><SPAN>;</SPAN><SPAN>category</SPAN><SPAN>=</SPAN><SPAN>Toyota</SPAN><SPAN>_</SPAN><SPAN>SUV</SPAN><SPAN>_</SPAN><SPAN>Truck</SPAN><SPAN>_</SPAN><SPAN>Tech</SPAN><SPAN>__</SPAN><SPAN>Newbie</SPAN><SPAN>_</SPAN><SPAN>Tech</SPAN><SPAN>_</SPAN><SPAN>Section</SPAN><SPAN>;</SPAN><SPAN>topic</SPAN><SPAN>=</SPAN><SPAN>99</SPAN><SPAN>%</SPAN><SPAN>204runner</SPAN><SPAN>%</SPAN><SPAN>20fix</SPAN><SPAN>%</SPAN><SPAN>20or</SPAN><SPAN>%</SPAN><SPAN>20not</SPAN><SPAN>%</SPAN><SPAN>20fix</SPAN><SPAN>%</SPAN><SPAN>20seems</SPAN><SPAN>%</SPAN><SPAN>20stuck</SPAN><SPAN>%</SPAN><SPAN>20in</SPAN><SPAN>%</SPAN><SPAN>204</SPAN><SPAN>%</SPAN><SPAN>20lo</SPAN><SPAN>;</SPAN><SPAN>sz</SPAN><SPAN>=</SPAN><SPAN>300x250</SPAN><SPAN>;</SPAN><SPAN>ord</SPAN><SPAN>=</SPAN><SPAN>123456789</SPAN></A>?" border="0" alt="" /></a> This ad is not di
rear wheel differential">rear wheel differential" /> rear wheel differential">rear wheel differential
. I am totally guessing here and if I sound stupid please forgive my ignorance, just love the truck like my favorite childhttps://www.yotatech.com/# toy(smile) and before I have to make tough decisions like possibly taking to the dealer I want to make sure I have a full understanding before Mr. Fuzzy Dealer mechanic takes me to the cleaners. Thanks in advance,
Trunner4
#1886
Im back, and with a 96 4runner
I've been out sick for a very long time but I am back at it and starting with my 96 i justed picked up this week. No major resto for now, just some mild engine upgrades and some appearance items.
#1887
Welp I am new so figured i might as well post up the rig. I frequent the t4r.org forum and found alot of swap info on here and figured it might be a good place to start for a v8 swap on a 2nd runner i just obtained.
Here is my rig that is slowly getting modded more and more...
98 Limited with 220k miles and counting
#1899
My '97 limited w/factory E-locker, sunroof and RS3000. Bone stock. I'm 2nd owner. purchased in July 2015. 149,000mi. Fully loaded minus the fog lamps(bummer). Run of the mill compared to all the nice T4Rs here but I love it and can't wait to drive it in the snow!
