Suspension problem
Suspension problem
Ok i go to get my new tires thrown on and alined, they tell me that both tie rods are shot and i need a new idler arm and pitman arm. They also quote me at 600 bucks. Now being the "do it yourselfer" how do i determine these things are accually bad and how hard is it to replace them. And if im going to be replaceing them, is there a better version than stock/napa parts that i should be looking into?
Thanks for any insight
With the right pullers it should be easy, most of the big auto parts stores loan out pullers for free. I'd get a second opinion, the pitman arms are very durable. What truck is it, and how old?
94 truck 4wd 22re
i played with the idler arm and it had some play, plus when i crank the wheel i hear a loud snaping noise
Originally Posted by silverCRXTC
94 truck 4wd 22re
http://www.off-road.com/toyota/tech/idler/index.html
Simple, easy, bam! Back on the road.
Originally Posted by mastacox
I took my 4runner to get aligned one day, and the guy said I needed a new pitman arm, and quoted me 300 bucks, but in reality the problem was just the idler arm bushings, an easy fix at four dollars. You should try replacing the bushings and see what that does, then decide...
I just replaced the outer tie rods on my 4Runner and it was easy, about an hour and half to do both sides. The best $9 you'll spend is on a tie rod puller. Just tighten that baby on and the tie rod pops out. Unscrewing the tie rod from the sleeve took longer than getting the tie rod out. I used a tie rod puller, socket set, pliers, a large crescent wrench & lots of PB blaster to loosen everything up.
For parts, check out Jay Marks Toyota world; http://www.trademotion.com/partlocat...?siteid=213747
Even with shipping, their Toyota parts are lots cheaper than my local dealer. I think you can order the whole inner/outer tie rod assembly and replace everything in one shot. I found that out too late, but maybe you can do that and save yourself some time.
Good luck!!
Good luck!!
i got some moog parts from carquest, they seem to be better than oem, they have grease fittings on all the joints where the oem seem to be sealed
Yotadawgjr
10
08-23-2015 11:51 AM
coffey50
07-28-2015 11:55 AM
Vargntucson
07-04-2015 01:15 PM
