Supercharger with or without the 170 thermo
Old 08-21-2015 | 01:46 PM
anniesball's Avatar
I have a 1st gen supercharger on a 2002 4Runner with the URD 7th injector kit. I've installed everything except the 170 degree thermostat.
I live in nothern Cal at about 3000' elevation.
I'm questioning if this is necessary for the whole kit to work properly? I'm concerned about the temperatures of the heater in the winter running the 170.
Thanks
Old 08-22-2015 | 07:12 AM
KZN185W's Avatar
Although the system would still work properly with the original thermostat, I would recommend to install that 170deg thermostat since you don't have an intercooler so it will help in keeping the engine temp near the normal operating temp.
it should not affect the heater during winter since it's not a big reduction in coolant temperature from the original coolant temp
Old 08-25-2015 | 06:41 PM
anniesball's Avatar
Ok thanks. Does it need to be a TRD thermostat or is Napa ok also?
Old 08-26-2015 | 06:11 AM
KZN185W's Avatar
I am not familiar with napa. If the money is not an issue, then I would go for TRD. I always buy OEM for my truck. It all boils down to which brand is reliable and would you trust.
Old 08-26-2015 | 09:02 AM
anniesball's Avatar
Thanks
Old 09-20-2015 | 05:59 PM
ThorInc's Avatar
OEM thermostat........the price difference is negligible at most.
Old 09-20-2015 | 07:54 PM
aa1911's Avatar
You don't need it certainly but it would be good.
Go OEM on the thermostat, when you hold the NAPA/Autozone brands up to the Toyota one and look at the difference, there's no contest. The Toyota one has a much larger opening.
Old 09-30-2015 | 04:18 AM
White Stripe's Avatar
I just created a thread on this, but the TRD 160 thermostat is just a motorad thermostat. Much cheaper to get a motorad one.
Old 09-30-2015 | 06:18 AM
vasinvictor's Avatar
160* just sounds like a terrible idea. Your engine needs the heat for proper combustion. I have ~350whp and never had a problem whatsoever. If you're concerned add a tiny methanol shot.
Old 09-30-2015 | 07:31 AM
With the 160 it has been reported you can increase the timing. With the 170 my engine temp dropped from 195 to 185, so if the 160 drops it a few more degrees I think that will help.
Old 09-30-2015 | 07:38 AM
How exactly are you adding timing anyway? A lower temp tstat is a bandaid at best. You need a way to lower the intake charge or add more fuel if you're worried about detonation. When you're not in boost, you're going to be causing more wear and worse motor efficiency. That's my .02.
Old 09-30-2015 | 07:55 AM
Im not a super genius and don't intend to be. People have reported that with the urd injector kit that also allows you to control timing that the colder tstat allows for less timing retardation of the stock ecu timing map by about 5 degrees. It was an older post by trdolman that I read it. I was just providing a way to save money rather than spend 80 bucks on the trd thermostat if the op wanted to do a 160 tstat. I just bought one and am going to try it. Its only 3 bolts and about 20 minutes to change a tstat on a 3.4. Not hard to change back if it doesn't work out.
Old 09-30-2015 | 09:09 AM
Fair enough. Just wanted people to know the possible caveats of this "mod". themoreyouknow.jpg
Steven.m.paulk
06-07-2020 11:45 AM
LCE_Performance
10-01-2015 02:03 PM
anniesball
10
09-15-2015 06:41 PM
anniesball
09-09-2015 10:55 AM
anniesball
09-07-2015 12:20 PM
