Supercharger Install ?'s
Old 11-11-2003 | 06:05 PM
ssbogger's Avatar
Hey guys, I just got my S/C in yesterday and will be putting it on this wkend. I was just wondering, from those who did it themselves, what to look out for. What will be the hardest part? Does TRD leave anything out in the instructions or not make something as clear as it should be? This is the first time I will be doing any major engine work by myself, although my dad is helping its his biggest task so far as well. About how long should we expect it to take?
Thanks in advance for the replys! Ill be sure to get out to the track and post end results!
Old 11-11-2003 | 06:34 PM
init6's Avatar
check out
http://www.gadgetonline.com
Make sure do you the fuel mods.
Old 11-11-2003 | 07:08 PM
ufjaz's Avatar
One thing I found useful was to label the hoses before I disconnected them. That way I could double check the new connections as I made them.
The hose hookup can get a little confusing. This was a good method for a sanity check.
Old 11-11-2003 | 07:38 PM
ssbogger's Avatar
Originally posted by init6
check out
Thanks for the tip, but I am very familiar with his site. Thanks anyways.
Old 11-11-2003 | 07:43 PM
Bob_98SR5's Avatar
Hey SS,
If you have the patience to skim through a search on "supercharger install" or (SC install), your question has been answered i believe in two or three threads with similiar titles (yeah, been on here too long to know!).
I believe SLC Punk (Travis) is the person who did the most recent install. Go bug him and tell him I sent ya!
Bob
Old 11-11-2003 | 08:01 PM
rwmorrisonjr's Avatar
From: Home: Aurora, CO; Work: The People's Republic of Denver
Be careful not to over-torque the manifold studs on the head. 13 ft/lbs is all you need. I know this from experience, I sheared off the one closest to the firewall after I had everything together! Luckily I have a great seal on it from all the other bolts so I've had no problems with it to date.
Old 11-12-2003 | 04:32 AM
4RunnerFever's Avatar
Hey Sam - congrats on the supercharger - you are gonna love it!!
Old 11-12-2003 | 06:08 AM
SLC Punk's Avatar
Bob
thanks Bob!
The main thing to do is take your time. My install took about 6 hours, but I was very careful to make sure everything was installed right. Make sure you have a good torque wrench in ft/lbs and one with in/lbs reading would also be helpful (since you torque some of the bolts to 10 ft lbs. Make sure you install the TB gasket the correct way.
What year do you have? My '97 had vacuum lines that the manual didn't show. Luckly, the members here helped me figure out the lines. I had to buy additional vacuum lines and "T" fittings.
If you are planning on changing the spark plugs or wires, do it now. You will have the best access before the S/C is installed. I didn't change my plugs until after I installed it. Its do-able but it would have been easier to do it during the install. The same goes for the Thermostat. My TRD thermostat is sitting on my tool box waiting to be installed this spring. To install it I will have to take off my S/C belt tensioner. It isn't hard to do this, but like I said above, it will be easier to do it during the install.
Its an easy install. If you have any questions, you can PM me for my cell phone #.
Old 11-12-2003 | 06:12 AM
tomstin's Avatar
A few things besides those that were mentioned. The power steering and AC belts are a PITA. Be patient, once you figure out the mechanism, it's not too bad, but they can be a knuckle buster. Next, installing the oil dip stick tube took me some time, it needs to be bent to fit, I had a heck of a time getting that lined up and out of the way of the belt. Make sure you installed the throttle body gasket the right way. And last, the one-way check valve, lot's of folks have missed that one.
Don't forget the cooler thermostat and plugs. Fill the tank up with 93 octane before you start the project.
Old 11-12-2003 | 09:54 AM
ssbogger's Avatar
Thanks for all the advice guys, excactly what i was looking for! About this thermostat, why do i need it? Thanks!
Old 11-12-2003 | 09:57 AM
SLC Punk's Avatar
Its one of the things that can help with the pinging problem that the S/C has. The 2-step colder plugs and TRD 160 Degree thermostat (according to TRD) will help with the high speed low rpm ping.
nvdesertrunner
05-11-2020 09:18 PM
punks_is_4x4
08-21-2015 02:35 PM
anniesball
07-29-2015 12:46 PM
mengquis
07-13-2015 11:39 AM
Cplmike
07-08-2015 09:47 PM
