Supercharger Belt Screech
I had my 45,000 mile work done and commented that my SC screeches under heavy acceleration and asked them to look into it. I figured that they would just tighten up the belt. But they came back with the news that I need a new belt and it’s gonna cost me about $25 bucks. To me that sounds kinda cheap. And I wonder if that’s really the problem. I remember some conversation a while back regarding a belt tensioner. Anyone have experience with this. Advice or Comments?
I had a belt squeal on my '99 Ford Lightning (superchrged) and there was a TSB on it. I took it to the dealer and they put a different belt on, (different composition? I duuno). Anyway; the squeal is gone now. Are you sure it's not the pulley though?
According to Alldata, there is a service bulletin on a squeak/rattle from idler. These are titles only, not the text of the bulletin. These might not be a free repair either.
http://www.alldata.com/
Bulletins for 1999 Toyota Truck 4 Runner SR5 4WD V6-3378cc 3.4L DOHC (5VZ-FE) MFI
Service Bulletins
TSB Number Issue Date TSB Title
BO030-01 DEC 01 Windshield Wiper Blade - Maintenance and Cleaning
EL010-01 OCT 01 Keyless Entry System - Identification/Programming
B0019-01 AUG 01 Seat Belts - Shoulder Belt Particle (Dirt) Buildup
EL005-01 AUG 01 Windows - Unintended Activation Of Rear Power Window
EG005-01 APR 01 EVAP System - Supplemental Operation/Diagnostics
BO013-01 APR 01 Door Mirror - Glass Service/Parts
BO011-01 MAR 01 Seat Belt Tongue Plate Stopper - New Parts
ST001-01 FEB 01 Steering Wheel Nut - Torque Standardization
BO002-01 JAN 01 Seat Belts - Extenders
BR007-00 DEC 00 Front Brake - Vibration
BR004-00 OCT 00 Brakes - Pad Clicking Noise
EL010-00 AUG 00 Instruments - Fuel Gauge Inaccurate
SC001-00 AUG 00 Supercharger - Squeak/Rattle Noises From Idler Pulley
AC002-00 JUL 00 A/C Compressor - Maintenance for Stored Vehicles
PG006-00 MAR 00 Emissions - CA/50 State Certified Emission Control Label
AX001-00 MAR 00 Vehicle - Towing Guide.
EL001-00 FEB 00 Windows - Power Window Diagnosis Procedure
BO002-00 JAN 00 Seat Belts - Extenders Available
EL010-99 DEC 99 Instruments - Fuel Gauge Calibration Procedure
PG032-99 DEC 99 Year 2000 Readiness Disclosure
EL006-99 OCT 99 Antitheft - Engine Immobilizer System Cautions
DL001-99 AUG 99 Drivetrain - Propeller Shaft Joint Grease/Fittings
SS002-99 JUL 99 1999 Special Service Tools
TC003-99 MAY 99 A/T - Fluid Interchangeability
PG018-99 MAY 99 Repair Manual Corrections - Locks
AX006-99 APR 99 Antitheft - Changes For GBS Glass Breakage System
AX005-99 APR 99 Antitheft - Programing the Remote Control
SS001-99 APR 99 Antitheft - Scantool Immobilizer Key Code Utility
EL002-99 MAR 99 Keyless Entry - Wireless Door Lock Buzzer Adjustment
AX004-99 MAR 99 Vehicle - Towing Guide
PA002-99 MAR 99 Paint - Refinish Formula Codes
SS003-98 DEC 98 Accessories - Rivet Nut Tool
EG012-98 NOV 98 Emissions - Oxygen Sensor Design Update
PA004-98 OCT 98 Paint - Codes & Color Combinations
PG008-98 AUG 98 PDI - Fuse Installation
Service Bulletins
Sorry cant help with the S/C belt, but if anyone knows what the details of this TSB is please let me know. Thanks.
**EDIT**
Got it
http://www.alldatadiy.com/alldata/AF...63452/85870682
Not the seat belt problem i am having anyway...
**EDIT**
Got it
They are indeed "warranty" repair. But with all the time I wasted at the stealer I cannot consider it "free". I been there 3 times to fix a rattle in my seat belt latch. My 4th appointment is schelduled in 2 weeks and will prolly be a waste of my time again.:mad:
primordialbeast117
12-19-2015 12:23 PM
LCE_Performance
10-01-2015 01:03 PM
