Stumbling Runner
Originally Posted by jjcale
I took it to the shop and belive it or not it would not produce the problem for them. I have no clue what this could be but he stated to replace the distributer. he stated that their is a bushing on the shaft that will wear down and touch the contacts to make it stumble. I am going to buy one tomarrow and we will see what happens. Im going nuts
#25
Originally Posted by yotaluver
whats a tps?
#26
have you checked the main distributor wire??? or the plugs and wires or the Cap and rotor... bet it's electrical... check your main Plug Wire (center wire from the coil) if it's got a short or a break in it that can happen. But TPS sounds very resonable too.
#27
Nothing yet
Originally Posted by 4-RUNNIN' FREAK
Any new updates?
#28
TS86 anythihg yet?
So I have a similar problem, BUT much more random. So I noted that if I kept from tightening the gas cap all the way say go to full lock then back off a 1/4 turn I had no stumbles. I wonder if there was too much vacuum in the system so much so that the pump could not push fuel anymore. I know it makes no sense, but I went about 5 tanks of gas with no stumble. I then tightened to full lock and lo and behold a stumble.
I am leaning towards the distributor, but I checked and was pretty close to spec.
JJ
JJ
Jnkml
07-06-2015 01:20 PM
