stuck on steering rag link ext. for body lift
hey I'm stuck at the steering rag link. how do I get those bolts off?? i PB blastered it, and tried a breaker bar.. maybe I'm just not strong enough?
what did you guys do to get it off? I need to slip my extension in there!
Re: stuck on steering rag link ext. for body lift
AIR TOOLS!
If you are talking about in the steering shaft where you put the spacer in. If so I could not get the bolts off with the nut at the bottem. I just took the upper nuts off. The with the lift it pulled rite apart.My spacer only had to bolts to replace two of the stock bolts stayed unmoved.
Re: Re: stuck on steering rag link ext. for body lift
Re: Re: Re: stuck on steering rag link ext. for body lift
wait, you only took 2 of the 4 bolts off? how did you stick the spacer in between?
Originally posted by waskillywabbit
Seriously, if you have already lifted it with that steering extension tight the whole time it might be in such tension it ain't coming off. I loosened mine before I ever started lifting.
I was just trying to get it off after he left, and couldn't
so I pb blastered it some more to see if that helps tomorrow
Sorry
waskilly, do you have a better pic of the steering ext. by any chance? the one on 4crawler.com is a little blury when you enlarge it...
Re: Sorry
Nope, didn't take any pics when I did the mod. I will take some when I take it off.
It pulled in two peices after I lifted it. I was 2 bolt that just poke though. Just 2 bolts are replaced.
if you can get a brass bar in there and tap the bolt head a couple times with a ball pein hammer, not hard like you're trying to mangle it, just a couple good solid taps like you do when the jelly jar lid is stuck on. that may bust her loose without the need for air tools. good luck dude.
thanks... its hard because the steering wants to turn when I twist the nut
Re: 2c
Originally posted by runningman
try turning your wheel while the ignition is off and the key is out of the tumbler, it should lock after a few degrees.
Flying91
45
04-11-2024 04:39 PM
09-04-2015 09:27 AM
skoti89
07-06-2015 07:45 PM
