Stuck in 4wd
Stuck in 4wd
Well I just got back from Afghanistan and my dad was driving my 4runner once a month to make sure everything was good. Well he didn't realize that he needed to drive it in 2wd and 4wd and just left it in 4 wheel. So now it's stuck. What do I need to check on to fix this? I was not happy when I got home today and I can't drive my truck around.
What exactly do you mean by 'stuck in 4WD'?
a)Light stays on--not sure about anything else
b)Front diff is engaged but TC not
c)Front diff, TC, are both engaged,
I can help, but I need to know what the problem is, specifically. I assume with a 5speed you actually can get the J-shift to disengage the TC. So you would not really be in 4wd.
Yeah. I the light goes off and clicks. The front unbinds a little bit. I think the transfer case has disengaged.
I guess I should retitle this, front end binding?
It's kind of sharp turn to get in to the garage, and I asked my dad if it was hard to do. He didn't realize it would be easier to if it was in 2wd. I guess I'll start my work on it a few weeks sooner.
Sonoran Steel 1.2 lift
Manual Hub Conversion
New power steering rack
New AC compressor
Rock sliders
+changing all the fluids
New AC compressor
Rock sliders
If you have manual hubs and they are in the free position why is it binding up?
If it has been driven on a hard surface everything could be pretty bound up. Try driving on a loose surface to help it unbind.
OK, switch them back. Then use a test light to see if electrical signal from the TC also switches sides of the VSV. If it does not, problem is the switch on the TC. If it does, but the vacuum does not, the problem is the VSV itself.
I start troubleshooting at the VSV's because you can figure out where the trouble is without having to climb under the truck.
My 96' Tacoma is stuck in 4 wheel low. I was driving in snow , I came to clean road an I shifted it back to2 wheel. Upon doing this it put the transfer case in neutral. Now I can't get it to go into anything. My brother was messing with it and got it into 4 wheel low. I removed the shifter and tried to move the linkage but it seems jammed. Anyone have any suggestions?
May-39
09-06-2015 02:05 PM
