Stock 22RE Specs?
Originally Posted by AzStorm
Which specs do you need?
Shoot me an e mail and I can give you the info.
Originally Posted by kyle_22r
22RE('85-95):
bore - 92mm
stroke - 89mm
compression ratio - 9.4:1
116hp @ 4800rpm
140tq @ 2800rpm
bore - 92mm
stroke - 89mm
116hp @ 4800rpm
140tq @ 2800rpm
If anyone has any more 22RE info, please post. Thanks again.
actually i think they all had 105 or so from '83-84, 116 from '85-89, and that there was a slight increase in '89 or so due to the better plenum that was introduced. but i could be wrong
HP and Torque Ratings
Toyota Stock Motors 1985 - 1986 - 1987 - 1988
22R 99 HP @ 4800 RPM TORQUE 129 @ 2900 RPM
22R CALIF. 95 HP @ 4800 RPM TORQUE 129 @ 2900 RPM
22RE 116 HP @ 4800 RPM TORQUE 140 @ 2900 RPM
22RET 135 HP @ 4800 RPM TORQUE 173 @ 2900 RPM
Toyota Stock Motors 1989 - 1990
22R & 22RE 103 HP @ 4800 RPM TORQUE 133 @ 2900 RPM
Toyota Stock Motors 1991 thru 1995
Same as 1989 - 1990
No 22R After 1990
Let me know what else you need.
Same as 1989 - 1990
No 22R After 1990
lots of 22re/te info here
http://www.well.com/user/mosk/
Originally Posted by AKennedy87
Not that I need it but is there any way to get rid of the things on the 89-95 that restricts it to only 103 hp?
A stock 22re California truck only makes CALIF. 95 HP @ 4800 RPM TORQUE 129 @ 2900 RPM "My truck currently push's 130 rwhp and 180 rwt"
I am still doing this with a stock computer and stock block wow
I did some thing good lol
coffey50
07-28-2015 10:55 AM
