Stinking damn EFI fuse
Sounds like a short in the wires running to the fuel pump most likely, or that the pump is pulling too much current. You could check by disconnecting the connector at the ful pump, often can be done through an access hatch under the rear seat. If the fuse still bolws, then the problem is in the wiring.
Anyone know how the friggin seats pop out?
If it is like the 1st gens, there is a sort of latch down behind the back of the cushion. As I recall, it has a loop on it that you pull up on the release the latch and lift the cushion with.
smilen724
13
11-08-2015 05:11 PM
Scotttekoch
09-28-2015 11:30 PM
