steering shaft extension?????
Old 09-26-2004 | 10:28 PM
Turtle_Toy98's Avatar
do u have to have a steering shaft extension with a 4'' suspension lift? I have a 98 tacoma 4x4. I have heard you do and I have heard you dont? I have a body lift on the truck now and already have a 3 inch extension, but do you need one with a susp. lift?
Old 09-26-2004 | 10:34 PM
jimbo74's Avatar
you dont need a steering shaft extension with a bodylift if you already have one.... the bodylift took care of that extension as the steering shaft is body related.....
however if you have a 4" suspension lift, you might want to look into dropped pitman arms or the like
Old 09-26-2004 | 10:37 PM
superjoe83's Avatar
the tacos use a rack and pinion type steering, so if you have a drop bracket type lift the steering shaft will have to be lengthened because the lift relocates the rack lower down
Old 09-26-2004 | 10:43 PM
jimbo74's Avatar
ah.... didnt know that... try contacting roger brown, he is 4crawler here..... check out his website www.4crawler.com , it imight have the info you need on it
Old 09-27-2004 | 07:46 AM
4Crawler's Avatar
As mentioned, if the lift kit drops the front axle and steering, then yes, you'll need to add a second extension. I've supplied a few of mine for that type of application, the body lift extension goes at the top of the shaft, my rag joint extension goes at the bottom. The lift kit would typically come with an extension, if its needed, but it would be for a stock height truck, it would not account for you already having a body lift. Contact the lift kit mfg. and ask them about the steering.
Old 09-29-2004 | 05:50 PM
Thanks guys.
Jcrawl94
10
10-24-2015 05:34 PM
4x4-runner
08-30-2015 09:55 AM
CratesCruiser
08-23-2015 07:12 AM
yoterr
07-24-2015 05:29 AM
andrewtexas123
07-14-2015 05:29 AM
