starting problems?
starting problems?
hey guys i was just courious as to why like every 1 out of say 10 or maybe even 15 times, the truck wont start up unless i give it some gas.... like i said it doesnt happen that often, just occassionally which is weird to me... its a 22 re motor, auto trans.... ive heard it could be cause the thrrottle body needs cleaning, and i did clean it somehwat the other day but i didnt do the full method with the carb cleaner and toothbrush... any other gueses? lemme know - steve
That definately souds like a leaky injector.
You giving it gas (actually you are giving the engine air) to burn the extra fuel puddling in the intake.
Originally posted by 4x4Fink
Sounds like the CSI...I had the same problem. Actually my problem was that the CSI wire had been cut so it wasn't workin at all!
Fink
Fink
Originally posted by grafix43
csi = cold start injector? how do i check it? and how much is it ?
make sure to check all wiring as was mentioned (verify with a multimeter) to ensure operation.
06-01-2021 01:51 PM
Regency
20
01-03-2020 07:43 PM
Jnkml
07-06-2015 01:20 PM
