Starter Problems
Old 08-25-2009 | 12:05 PM
RS964WD's Avatar
Starter Problems
Hey guys im sure there are quite a few post here about the problem im just starting to have, but every case is different, I have a 96 Limited T4R 4WD with 135,000miles, ive noticed that about a week ago when i get in and turn the ignition it clicks once, then its starts after the second try, but then yesterday i had to turn the ignition about 2 min clicking before it finally started, i have had the truck for only about a month, so i havent really gotten into it, but what is causing the clicking? is my starter going bad, or is it something else? what can i do to either save it or save my self a headache later on......... Thanks
Old 08-25-2009 | 12:14 PM
KrashDH's Avatar
Your contacts are worn. Pull the starter and replace the two starter contacts. They tend to wear unevenly so one side will have a big groove and the other will not. The replacement OEM set was about $22, but beats buying a new or reman starter.
I had the exact issues about a month ago and I replaced mine and all is well.
Old 08-25-2009 | 12:45 PM
brian2sun's Avatar
KrashDH is right. It's better to replace the contacts on your OEM starter. Aftermarket starters are generally crap compared to your stock one.
Old 08-25-2009 | 01:20 PM
RS964WD's Avatar
Ok so i was close to what i thought it was, ive never changed contacts on a starter, is that something i can do with basic tools in my garage? would anybody happen to have pics of this job? or maybe a quick review of the procedure? thanks again guys
Old 08-25-2009 | 01:28 PM
4Crawler's Avatar
See below for all you need to know:
- http://www.4crawler.com/4x4/CheapTricks/Starter.shtml
Old 08-25-2009 | 01:56 PM
BigBallsMcFalls's Avatar
not if you get one from a toyota dealer. they are 100% used, but 110% better than original. all the proper guts have been upgraded (contacts, bearings, brushes...)
Old 08-25-2009 | 02:31 PM
brian2sun's Avatar
Used re-man Toyota starters are good. I mean "aftermarket" as in other brands like Autozone or Kragen brand starters. Those suck compared to new or rebuilt Toyota starters.
Old 08-25-2009 | 05:40 PM
KrashDH's Avatar
Here is my thread on the starter thing.
https://www.yotatech.com/forums/f2/p...-issue-184572/
If you scroll down I took a pic of the orientation to get the starter out (for a Tacoma) and the actual worn contacts. Hope this helps a bit.
Old 08-26-2009 | 12:09 PM
RS964WD's Avatar
alright ill try it, cause its not getting any better. thanks
toyotamonster
3.4 Swaps
7
04-16-2020 07:02 PM
clok
08-01-2015 10:42 PM
Hiluxtrucha
07-22-2015 11:00 AM
ZONAYODA
07-13-2015 08:17 PM
colinmil
07-06-2015 05:03 PM
