Is it the starter?
Old 10-03-2004 | 04:56 AM
heholaday's Avatar
Question Is it the starter?
The last few weeks, most times I try to start my Runner up it just makes a clicking sound and doesn't even attempt to turn over. I found that when it does this, if I turn the key on, wait a few seconds (after I hear a couple of clicks under the hood) it usually will start right up. Sometimes this process takes several tries. Is my starter going bad?
Old 10-03-2004 | 05:03 AM
Cebby's Avatar
Clicking sound is usually an indication of low voltage. Starter problems are "usually" indicated by no noise at all - turn the key and get absolutely nothing. Get a load test done on your battery.
I'm guessing you didn't search since I typed a similar response yesterday for someone else with a similar issue.
Old 10-03-2004 | 05:17 AM
heholaday's Avatar
Yeah, actually I did search and most of the posts are talking about the contacts...I'll check the battery load first.
Old 10-03-2004 | 08:11 AM
Jonathan's Avatar
Might be an ignition coil, Take it to Autozone and they'll run a battery, alternator and starter test for free, that way you can narrow it down.
Old 10-03-2004 | 08:44 AM
Rick F.'s Avatar
From: Far western Kentucky (transplanted from central PA)
Certainly sounds like a voltage problem. You could luck-out and just have dirty battery cable terminals.
Old 10-03-2004 | 09:12 AM
4Crawler's Avatar
I have some troubleshooting ideas on my starter repair page...
ladybugRC
458
08-21-2020 11:41 AM
pickle6415
10-19-2015 09:08 AM
zombie_barbarossa
10-02-2015 11:54 PM
bradahman
10-01-2015 10:24 AM
beltcutter
09-30-2015 07:14 AM
